prosim o kontrolu MWAV
mafian
Příspěvekod mafian » 17 úno 2007 18:43
zdravim jak se mam zbavit total erors :16
zde přikládám log děkuji předem
Sat Feb 17 17:54:50 2007 => MWAV in SPECIAL PROMOTION MODE.
Sat Feb 17 17:54:50 2007 => **********************************************************
Sat Feb 17 17:54:50 2007 => MicroWorld Anti Virus & Spyware Toolkit Utility.
Sat Feb 17 17:54:50 2007 => Copyright © 2003-2006, MicroWorld Technologies Inc.
Sat Feb 17 17:54:50 2007 => Source: C:\mwav.exe
Sat Feb 17 17:54:50 2007 => Version 9.1.4 (C:\DOCUME~1\User\LOCALS~1\Temp\mexe.com)
Sat Feb 17 17:54:50 2007 => Log File: C:\DOCUME~1\User\LOCALS~1\Temp\MWAV.LOG
Sat Feb 17 17:54:50 2007 => MWAV Registered: TRUE.
Sat Feb 17 17:54:50 2007 => User Account: User
Sat Feb 17 17:54:50 2007 => OS Type: Windows Workstation
Sat Feb 17 17:54:50 2007 => OS: Windows XP
Sat Feb 17 17:54:50 2007 => Ver: Service Pack 2 (Build 2600)
Sat Feb 17 17:54:50 2007 => Windows Root Folder: C:\WINDOWS
Sat Feb 17 17:54:50 2007 => Windows Sys32 Folder: C:\WINDOWS\system32
Sat Feb 17 17:54:50 2007 => Local Fixed Drives: c:\,d:\
Sat Feb 17 17:54:50 2007 => MWAV Mode: Scan and Clean files (for viruses, adware and spyware).
Sat Feb 17 17:54:50 2007 => Latest Date of files inside MWAV: 16 Feb 2007 11:37:1.
Sat Feb 17 17:54:54 2007 => AV Library Loaded...
Sat Feb 17 17:54:54 2007 => MWAV doing self scanning...
Sat Feb 17 17:54:54 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\Getvlist.exe
Sat Feb 17 17:54:54 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\main.avi
Sat Feb 17 17:54:54 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\virus.avi
Sat Feb 17 17:54:54 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\ScanningProcess.exe
Sat Feb 17 17:54:54 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\Kave.dll
Sat Feb 17 17:54:54 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\prloader.dll
Sat Feb 17 17:54:54 2007 => MWAV files are clean.
Sat Feb 17 17:55:09 2007 => Virus Database Date: 2/16/2007
Sat Feb 17 17:55:09 2007 => Virus Database Count: 267976
Sat Feb 17 17:55:13 2007 => Downloading AntiVirus and Anti-Spyware Databases...
Sat Feb 17 18:08:17 2007 => Downloads Aborted!
Sat Feb 17 18:09:14 2007 => **********************************************************
Sat Feb 17 18:09:14 2007 => MicroWorld Anti Virus & Spyware Toolkit Utility.
Sat Feb 17 18:09:14 2007 => Copyright © 2003-2006, MicroWorld Technologies Inc.
Sat Feb 17 18:09:14 2007 => Support: support@mwti.net
Sat Feb 17 18:09:14 2007 => Web: http://www.mwti.net
Sat Feb 17 18:09:14 2007 => Version 9.1.4 (C:\DOCUME~1\User\LOCALS~1\Temp\mexe.com)
Sat Feb 17 18:09:14 2007 => Log File: C:\DOCUME~1\User\LOCALS~1\Temp\MWAV.LOG
Sat Feb 17 18:09:14 2007 => User Account: User
Sat Feb 17 18:09:14 2007 => Windows Root Folder: C:\WINDOWS
Sat Feb 17 18:09:14 2007 => Windows Sys32 Folder: C:\WINDOWS\system32
Sat Feb 17 18:09:14 2007 => OS: Windows XP
Sat Feb 17 18:09:14 2007 => Ver: Service Pack 2 (Build 2600)
Sat Feb 17 18:09:14 2007 => Latest Date of files inside MWAV: 16 Feb 2007 11:37:1.
Sat Feb 17 18:09:14 2007 => Options Selected by User:
Sat Feb 17 18:09:14 2007 => Memory Check: Enabled
Sat Feb 17 18:09:14 2007 => Registry Check: Enabled
Sat Feb 17 18:09:14 2007 => StartUp Folder Check: Enabled
Sat Feb 17 18:09:14 2007 => System Folder Check: Enabled
Sat Feb 17 18:09:14 2007 => System Area Check: Disabled
Sat Feb 17 18:09:14 2007 => Services Check: Enabled
Sat Feb 17 18:09:14 2007 => Drive Check Option Disabled
Sat Feb 17 18:09:14 2007 => Folder Check: Disabled
Sat Feb 17 18:09:16 2007 => ***** Scanning Memory Files *****
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\System32\smss.exe
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\system32\ntdll.dll
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\SYSTEM32\CSRSS.EXE
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\system32\CSRSRV.dll
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\system32\basesrv.dll
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\system32\winsrv.dll
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\system32\GDI32.dll
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\system32\KERNEL32.dll
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\system32\USER32.dll
Sat Feb 17 18:09:16 2007 => Scanning File C:\WINDOWS\system32\sxs.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\ADVAPI32.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\RPCRT4.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\Apphelp.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\VERSION.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\SYSTEM32\WINLOGON.EXE
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\AUTHZ.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\msvcrt.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\CRYPT32.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\MSASN1.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\NDdeApi.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\PROFMAP.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\NETAPI32.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\USERENV.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\PSAPI.DLL
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\REGAPI.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\Secur32.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\SETUPAPI.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\WINSTA.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\WINTRUST.dll
Sat Feb 17 18:09:17 2007 => Scanning File C:\WINDOWS\system32\IMAGEHLP.dll
Sat Feb 17 18:09:18 2007 => Scanning File C:\WINDOWS\system32\WS2_32.dll
Sat Feb 17 18:09:18 2007 => Scanning File C:\WINDOWS\system32\WS2HELP.dll
Sat Feb 17 18:09:18 2007 => Scanning File C:\WINDOWS\system32\IMM32.DLL
Sat Feb 17 18:09:18 2007 => Scanning File C:\WINDOWS\system32\MSGINA.dll
Sat Feb 17 18:09:18 2007 => Scanning File C:\WINDOWS\system32\SHELL32.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\SHLWAPI.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\COMCTL32.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\ODBC32.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\comdlg32.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\odbcint.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\SHSVCS.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\sfc.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\sfc_os.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\ole32.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\msctfime.ime
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\WINSCARD.DLL
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\WTSAPI32.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\uxtheme.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\WINMM.dll
Sat Feb 17 18:09:20 2007 => Scanning File C:\WINDOWS\system32\cscdll.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\WlNotify.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\WINSPOOL.DRV
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\MPR.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\rsaenh.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\msv1_0.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\iphlpapi.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\wldap32.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\SAMLIB.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\cscui.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\xpsp2res.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\COMRes.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\OLEAUT32.dll
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\NTMARTA.DLL
Sat Feb 17 18:09:21 2007 => Scanning File C:\WINDOWS\system32\CLBCATQ.DLL
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\wdmaud.drv
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\msacm32.drv
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\MSACM32.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\midimap.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\services.exe
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\SCESRV.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\umpnpmgr.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\NCObjAPI.DLL
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\MSVCP60.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\ShimEng.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\AppPatch\AcGenral.DLL
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\eventlog.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\lsass.exe
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\LSASRV.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\NTDSAPI.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\DNSAPI.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\SAMSRV.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\cryptdll.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\msprivs.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\kerberos.dll
Sat Feb 17 18:09:22 2007 => Scanning File C:\WINDOWS\system32\netlogon.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\w32time.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\schannel.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\wdigest.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\scecli.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\ipsecsvc.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\oakley.DLL
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\WINIPSEC.DLL
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\mswsock.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\pstorsvc.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\hnetcfg.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\psbase.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\System32\wshtcpip.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\dssenh.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\svchost.exe
Sat Feb 17 18:09:23 2007 => Scanning File c:\windows\system32\rpcss.dll
Sat Feb 17 18:09:23 2007 => Scanning File c:\windows\system32\termsrv.dll
Sat Feb 17 18:09:23 2007 => Scanning File c:\windows\system32\ICAAPI.dll
Sat Feb 17 18:09:23 2007 => Scanning File c:\windows\system32\mstlsapi.dll
Sat Feb 17 18:09:23 2007 => Scanning File c:\windows\system32\ACTIVEDS.dll
Sat Feb 17 18:09:23 2007 => Scanning File c:\windows\system32\adsldpc.dll
Sat Feb 17 18:09:23 2007 => Scanning File c:\windows\system32\ATL.DLL
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\System32\winrnr.dll
Sat Feb 17 18:09:23 2007 => Scanning File C:\WINDOWS\system32\rasadhlp.dll
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\dhcpcsvc.dll
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\wzcsvc.dll
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\rtutils.dll
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\WMI.dll
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\ESENT.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\System32\rastls.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\system32\CRYPTUI.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\system32\WININET.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\system32\Normaliz.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\system32\iertutil.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\System32\MPRAPI.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\System32\RASAPI32.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\System32\rasman.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\System32\TAPI32.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\System32\raschap.dll
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\schedsvc.dll
Sat Feb 17 18:09:24 2007 => Scanning File C:\WINDOWS\System32\MSIDLE.DLL
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\audiosrv.dll
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\wkssvc.dll
Sat Feb 17 18:09:24 2007 => Scanning File c:\windows\system32\qmgr.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\SHFOLDER.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\WINHTTP.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\cryptsvc.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\certcli.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\dmserver.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\ersvc.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\es.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\pchealth\helpctr\binaries\pchsvc.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\srvsvc.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\netman.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\netshell.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\credui.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\WZCSAPI.DLL
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\seclogon.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\sens.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\srsvc.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\POWRPROF.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\trkwks.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\browser.dll
Sat Feb 17 18:09:25 2007 => Scanning File c:\windows\system32\wuauserv.dll
Sat Feb 17 18:09:25 2007 => Scanning File C:\WINDOWS\system32\wuaueng.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\System32\ADVPACK.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\System32\Cabinet.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\System32\mspatcha.dll
Sat Feb 17 18:09:26 2007 => Scanning File c:\windows\system32\wbem\wmisvc.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\system32\VSSAPI.DLL
Sat Feb 17 18:09:26 2007 => Scanning File c:\windows\system32\ipnathlp.dll
Sat Feb 17 18:09:26 2007 => Scanning File c:\windows\system32\wscsvc.dll
Sat Feb 17 18:09:26 2007 => Scanning File c:\windows\system32\msi.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\system32\comsvcs.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\system32\colbact.DLL
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\system32\MTXCLU.DLL
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\system32\WSOCK32.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\System32\CLUSAPI.DLL
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\System32\RESUTILS.DLL
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\system32\wbem\wbemcomn.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\System32\Wbem\wbemcore.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\System32\Wbem\esscli.dll
Sat Feb 17 18:09:26 2007 => Scanning File C:\WINDOWS\System32\Wbem\FastProx.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\wbem\wmiutils.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\wbem\repdrvfs.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\wbem\wmiprvsd.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\wbem\wbemess.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\wbem\ncprov.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\upnp.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\SSDPAPI.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\System32\RASDLG.dll
Sat Feb 17 18:09:27 2007 => Scanning File c:\windows\system32\tapisrv.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\netcfgx.dll
Sat Feb 17 18:09:27 2007 => Scanning File c:\windows\system32\rasmans.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\System32\rastapi.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\System32\unimdm.tsp
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\System32\uniplat.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\System32\unimdmat.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\system32\modemui.dll
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\System32\kmddsp.tsp
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\System32\ndptsp.tsp
Sat Feb 17 18:09:27 2007 => Scanning File C:\WINDOWS\System32\ipconf.tsp
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\System32\h323.tsp
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\System32\hidphone.tsp
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\System32\HID.DLL
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\System32\rasppp.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\System32\ntlsapi.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\wups.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\msxml3.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\wbem\wbemsvc.dll
Sat Feb 17 18:09:28 2007 => Scanning File c:\windows\system32\dnsrslvr.dll
Sat Feb 17 18:09:28 2007 => Scanning File c:\windows\system32\lmhsvc.dll
Sat Feb 17 18:09:28 2007 => Scanning File c:\windows\system32\webclnt.dll
Sat Feb 17 18:09:28 2007 => Scanning File c:\windows\system32\regsvc.dll
Sat Feb 17 18:09:28 2007 => Scanning File c:\windows\system32\ssdpsrv.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\spoolsv.exe
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\SPOOLSS.DLL
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\localspl.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\cnbjmon.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\CNMLM53.DLL
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\pjlmon.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\tcpmon.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\system32\usbmon.dll
Sat Feb 17 18:09:28 2007 => Scanning File C:\WINDOWS\System32\spool\PRTPROCS\W32X86\CNMPD53.DLL
Sat Feb 17 18:09:29 2007 => Scanning File C:\WINDOWS\system32\win32spl.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\WINDOWS\system32\NETRAP.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\WINDOWS\system32\inetpp.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswUpdSv.exe
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswCmnS.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswCmnOS.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\WINDOWS\system32\MSVCP71.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\WINDOWS\system32\MSVCR71.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswCmnB.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashServ.exe
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswAux.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswEngin.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswScan.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashBase.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashTask.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswInteg.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswIdle.dll
Sat Feb 17 18:09:29 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\Aavm4h.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\WINDOWS\system32\dbghelp.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\Czech\Base.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\UNACEV2.DLL
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\AhResMai.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ahResMes.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\AhResOut.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ahResP2P.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\AhResStd.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\AhResWS.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashSSqlt.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\WINDOWS\system32\ICMP.DLL
Sat Feb 17 18:09:30 2007 => Scanning File C:\WINDOWS\system32\perfos.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\WINDOWS\system32\nvsvc32.exe
Sat Feb 17 18:09:30 2007 => Scanning File C:\WINDOWS\system32\NVRSCS.DLL
Sat Feb 17 18:09:30 2007 => Scanning File c:\windows\system32\wiaservc.dll
Sat Feb 17 18:09:30 2007 => Scanning File c:\windows\system32\CFGMGR32.dll
Sat Feb 17 18:09:30 2007 => Scanning File c:\windows\system32\mscms.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\WINDOWS\system32\actxprxy.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\WINDOWS\system32\sti.dll
Sat Feb 17 18:09:30 2007 => Scanning File C:\WINDOWS\Explorer.EXE
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\BROWSEUI.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\SHDOCVW.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\themeui.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\MSIMG32.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\msutb.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\MSCTF.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\ieframe.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\urlmon.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\LINKINFO.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\ntshrui.dll
Sat Feb 17 18:09:31 2007 => Scanning File C:\WINDOWS\system32\MLANG.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\mshtml.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\msls31.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\msimtf.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\webcheck.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\stobject.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\BatMeter.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\upnpui.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\browselc.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\DUSER.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\System32\drprov.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\System32\ntlanman.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\System32\NETUI0.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\System32\NETUI1.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\System32\davclnt.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\shmedia.dll
Sat Feb 17 18:09:32 2007 => Scanning File C:\WINDOWS\system32\MSVFW32.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\AVIFIL32.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\wmvcore.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\WMASF.DLL
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.2180_x-ww_522f9f82\gdiplus.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\qasf.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\quartz.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\msdmo.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\PROGRA~1\COMBIN~1\Filters\FFDShow\ffdshow.ax
Sat Feb 17 18:09:33 2007 => Scanning File C:\PROGRA~1\COMBIN~1\Filters\FFDShow\MSVCR71.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\DINPUT.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\PROGRA~1\COMBIN~1\Filters\VSFilter.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\divxaf.ax
Sat Feb 17 18:09:33 2007 => Scanning File C:\WINDOWS\system32\wmvdmod.dll
Sat Feb 17 18:09:33 2007 => Scanning File C:\PROGRA~1\COMMON~1\ALPARY~1\Filters\YV12TO~1.AX
Sat Feb 17 18:09:33 2007 => Scanning File C:\PROGRA~1\COMMON~1\Ahead\DSFilter\NeVideo.ax
Sat Feb 17 18:09:34 2007 => Scanning File C:\WINDOWS\system32\ddraw.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\WINDOWS\system32\DCIMAN32.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\PROGRA~1\COMMON~1\Ahead\Lib\AdvrCntr.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\WINDOWS\system32\qdvd.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\WINDOWS\system32\shdoclc.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\WINDOWS\system32\icm32.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\WINDOWS\system32\wzcdlg.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\WINDOWS\system32\msrle32.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\WINDOWS\system32\qedit.dll
Sat Feb 17 18:09:34 2007 => Scanning File C:\PROGRA~1\COMBIN~1\Filters\Haali\splitter.ax
Sat Feb 17 18:09:34 2007 => Scanning File C:\PROGRA~1\COMBIN~1\Filters\Haali\mkzlib.dll
Sat Feb 17 18:09:35 2007 => Scanning File C:\PROGRA~1\COMBIN~1\Filters\Haali\MKUNIC~1.DLL
Sat Feb 17 18:09:35 2007 => Scanning File C:\PROGRA~1\COMBIN~1\Filters\Haali\mkx.dll
Sat Feb 17 18:09:35 2007 => Scanning File C:\PROGRA~1\COMBIN~1\Filters\Haali\avi.dll
Sat Feb 17 18:09:35 2007 => Scanning File C:\WINDOWS\system32\devenum.dll
Sat Feb 17 18:09:35 2007 => Scanning File C:\WINDOWS\system32\wdfmgr.exe
Sat Feb 17 18:09:35 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashMaiSv.exe
Sat Feb 17 18:09:35 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashUInt.dll
Sat Feb 17 18:09:35 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\XT1922.dll
Sat Feb 17 18:09:35 2007 => Scanning File C:\WINDOWS\system32\MFC71.DLL
Sat Feb 17 18:09:35 2007 => Scanning File C:\WINDOWS\system32\RICHED20.DLL
Sat Feb 17 18:09:35 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\Czech\Lang.dll
Sat Feb 17 18:09:35 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\Czech\langmai.dll
Sat Feb 17 18:09:35 2007 => Scanning File C:\WINDOWS\Mixer.exe
Sat Feb 17 18:09:36 2007 => Scanning File C:\WINDOWS\System32\cmnprop.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswCmnOS.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashBase.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswCmnB.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswCmnS.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashTask.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\aswAux.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\Aavm4h.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\AavmRpch.dll
Sat Feb 17 18:09:36 2007 => Scanning File c:\PROGRA~1\ALWILS~1\avast4\ahruimai.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashUInt.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\XT1922.dll
Sat Feb 17 18:09:36 2007 => Scanning File c:\PROGRA~1\ALWILS~1\avast4\ahruimes.dll
Sat Feb 17 18:09:36 2007 => Scanning File c:\PROGRA~1\ALWILS~1\avast4\ahruiout.dll
Sat Feb 17 18:09:36 2007 => Scanning File C:\WINDOWS\system32\MAPI32.dll
Sat Feb 17 18:09:36 2007 => Scanning File c:\PROGRA~1\ALWILS~1\avast4\ahruip2p.dll
Sat Feb 17 18:09:37 2007 => Scanning File c:\PROGRA~1\ALWILS~1\avast4\ahruistd.dll
Sat Feb 17 18:09:37 2007 => Scanning File c:\PROGRA~1\ALWILS~1\avast4\ahruiws.dll
Sat Feb 17 18:09:37 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashWebSv.exe
Sat Feb 17 18:09:37 2007 => Scanning File C:\WINDOWS\system32\security.dll
Sat Feb 17 18:09:37 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashWsFtr.dll
Sat Feb 17 18:09:37 2007 => Scanning File C:\WINDOWS\system32\OLEACC.dll
Sat Feb 17 18:09:37 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\AhResWs.dll
Sat Feb 17 18:09:37 2007 => Scanning File C:\WINDOWS\system32\rsvpsp.dll
Sat Feb 17 18:09:37 2007 => Scanning File C:\PROGRA~1\SPYWAR~1\SPYWAR~2.EXE
Sat Feb 17 18:09:37 2007 => Scanning File C:\PROGRA~1\ICQLite\ICQLite.exe
Sat Feb 17 18:09:38 2007 => Scanning File C:\WINDOWS\system32\MFC42.DLL
Sat Feb 17 18:09:38 2007 => Scanning File C:\PROGRA~1\ICQLite\ICQRT.dll
Sat Feb 17 18:09:38 2007 => Scanning File C:\PROGRA~1\ICQLite\LITESK~1.DLL
Sat Feb 17 18:09:38 2007 => Scanning File C:\PROGRA~1\ICQLite\ICQLSRP.dll
Sat Feb 17 18:09:38 2007 => Scanning File C:\PROGRA~1\ICQLite\EMOEXT~1.DLL
Sat Feb 17 18:09:38 2007 => Scanning File C:\WINDOWS\system32\OLEPRO32.DLL
Sat Feb 17 18:09:38 2007 => Scanning File C:\WINDOWS\system32\MFC42LOC.DLL
Sat Feb 17 18:09:38 2007 => Scanning File C:\PROGRA~1\ICQLite\LiteRes.dll
Sat Feb 17 18:09:38 2007 => Scanning File C:\PROGRA~1\ICQLite\MISB.dll
Sat Feb 17 18:09:38 2007 => Scanning File C:\PROGRA~1\ICQLite\actskin4.ocx
Sat Feb 17 18:09:38 2007 => Scanning File C:\PROGRA~1\ICQLite\LiteUtil.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\RICHED32.DLL
Sat Feb 17 18:09:39 2007 => Scanning File C:\PROGRA~1\ICQLite\ICQLIT~1.DLL
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\asycfilt.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\jscript.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\ImgUtil.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\pngfilt.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\Dxtrans.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\ddrawex.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\Dxtmsft.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\USP10.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\mshtmled.dll
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\Macromed\Flash\Flash9b.ocx
Sat Feb 17 18:09:39 2007 => Scanning File C:\WINDOWS\system32\iepeers.dll
Sat Feb 17 18:09:40 2007 => Scanning File C:\WINDOWS\system32\vbscript.dll
Sat Feb 17 18:09:40 2007 => Scanning File C:\WINDOWS\system32\ctfmon.exe
Sat Feb 17 18:09:40 2007 => Scanning File C:\WINDOWS\System32\alg.exe
Sat Feb 17 18:09:40 2007 => Scanning File C:\PROGRA~1\WINCLA~1\sp_clam.exe
Sat Feb 17 18:09:40 2007 => Scanning File C:\PROGRA~1\WINCLA~1\clamav.dll
Sat Feb 17 18:09:40 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\mexe.com
Sat Feb 17 18:09:40 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\msvl64.dll
Sat Feb 17 18:09:40 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\kave.dll
Sat Feb 17 18:09:40 2007 => Scanning File C:\WINDOWS\system32\VDMDBG.DLL
Sat Feb 17 18:09:40 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\ScanningProcess.exe
Sat Feb 17 18:09:40 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\prloader.dll
Sat Feb 17 18:09:41 2007 => Scanning File C:\DOCUME~1\User\LOCALS~1\Temp\prkernel.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\avpmgr.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\wdiskio.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\nfio.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\avlib.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\dtreg.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\prutil.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\avp1.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\l_llio.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\ichk2.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\sfdb.ppl
Sat Feb 17 18:09:41 2007 => Scanning File c:\docume~1\user\locals~1\temp\icheckersa.ppl
Sat Feb 17 18:09:41 2007 => Scanning File C:\PROGRA~1\Opera\Opera.exe
Sat Feb 17 18:09:41 2007 => Scanning File C:\PROGRA~1\Opera\Opera.dll
Sat Feb 17 18:09:44 2007 => Scanning File C:\PROGRA~1\Opera\Program\Plugins\NPSWF32.dll
Sat Feb 17 18:09:44 2007 => ***** Scanning Registry Files *****
Sat Feb 17 18:09:44 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad
Sat Feb 17 18:09:44 2007 => Scanning File C:\WINDOWS\system32\SHELL32.dll
Sat Feb 17 18:09:44 2007 => Scanning File C:\WINDOWS\system32\webcheck.dll
Sat Feb 17 18:09:44 2007 => Scanning File C:\WINDOWS\system32\stobject.dll
Sat Feb 17 18:09:44 2007 => Scanning File C:\WINDOWS\system32\upnpui.dll
Sat Feb 17 18:09:44 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad
Sat Feb 17 18:09:44 2007 => Scanning HKLM\SOFTWARE\Microsoft\Internet Explorer\Plugins\Extension
Sat Feb 17 18:09:44 2007 => Scanning HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar
Sat Feb 17 18:09:44 2007 => Scanning File C:\PROGRA~1\Canon\EASY-W~1\Toolband.dll
Sat Feb 17 18:09:44 2007 => Scanning File C:\PROGRA~1\Yahoo!\COMPAN~1\Installs\cpn\yt.dll
Sat Feb 17 18:09:44 2007 => Scanning File C:\PROGRA~1\ICQTOO~1\toolbaru.dll
Sat Feb 17 18:09:45 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\explorer\Browser Helper Objects
Sat Feb 17 18:09:45 2007 => {02478D38-C3F9-4EFB-9B51-7695ECA05670} = C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\PROGRA~1\Yahoo!\COMPAN~1\Installs\cpn\yt.dll
Sat Feb 17 18:09:45 2007 => {055FD26D-3A88-4e15-963D-DC8493744B1D} = C:\Program Files\ICQToolbar\toolbaru.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\PROGRA~1\ICQTOO~1\toolbaru.dll
Sat Feb 17 18:09:45 2007 => {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} = C:\Program Files\Adobe\Acrobat 6.0 CE\Reader\ActiveX\AcroIEHelper.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\PROGRA~1\Adobe\ACROBA~1.0CE\Reader\ActiveX\ACROIE~1.DLL
Sat Feb 17 18:09:45 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\explorer\SharedTaskScheduler
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\browseui.dll
Sat Feb 17 18:09:45 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\mmsys.cpl
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\icmui.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\rshx32.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\docprop.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\ntshrui.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\themeui.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\deskadp.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\deskmon.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\dssec.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\SlayerXP.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\shscrap.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\diskcopy.dll
Sat Feb 17 18:09:45 2007 => Scanning File C:\WINDOWS\system32\ntlanui2.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\System32\icmui.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\icmui.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\printui.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\dskquoui.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\syncui.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\fontext.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\rshx32.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\ntshrui.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\deskperf.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\cryptext.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\NETSHELL.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\wiashext.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\remotepg.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\wshext.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\PROGRA~1\COMMON~1\System\OLEDB~1\oledb32.dll
Sat Feb 17 18:09:46 2007 => Scanning File C:\WINDOWS\system32\mstask.dll
Sat Feb 17 18:09:47 2007 => Scanning File C:\WINDOWS\system32\mstask.dll
Sat Feb 17 18:09:47 2007 => Scanning File C:\WINDOWS\system32\shdocvw.dll
Sat Feb 17 18:09:47 2007 => Scanning File C:\WINDOWS\system32\wuaucpl.cpl
Sat Feb 17 18:09:47 2007 => Scanning File C:\WINDOWS\system32\twext.dll
Sat Feb 17 18:09:47 2007 => Scanning File C:\WINDOWS\system32\shmedia.dll
Sat Feb 17 18:09:47 2007 => Scanning File C:\WINDOWS\system32\browseui.dll
Sat Feb 17 18:09:47 2007 => Scanning File C:\WINDOWS\system32\ieframe.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\ieframe.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\shdocvw.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\sendmail.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\occache.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\webcheck.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\appwiz.cpl
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\shimgvw.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\netplwiz.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\zipfldr.dll
Sat Feb 17 18:09:48 2007 => Scanning File C:\WINDOWS\system32\extmgr.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\msieftp.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\docprop2.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\dsquery.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\dsuiext.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\mydocs.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\System32\cscui.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\msagent\agentpsh.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\dfsshlex.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\photowiz.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\System32\mmcshext.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\cabview.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\PROGRA~1\OUTLOO~1\wabfind.dll
Sat Feb 17 18:09:49 2007 => Scanning File C:\WINDOWS\system32\wmpshell.dll
Sat Feb 17 18:09:50 2007 => Scanning File C:\WINDOWS\system32\wmpshell.dll
Sat Feb 17 18:09:50 2007 => Scanning File C:\WINDOWS\system32\nvcpl.dll
Sat Feb 17 18:09:50 2007 => Scanning File C:\WINDOWS\system32\nvshell.dll
Sat Feb 17 18:09:50 2007 => Scanning File C:\PROGRA~1\OPENOF~1.3\program\shlxthdl.dll
Sat Feb 17 18:09:50 2007 => Scanning File C:\PROGRA~1\JetAudio\JetFlExt.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\PROGRA~1\WinRAR\rarext.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\PROGRA~1\ILLUST~1\DBPOWE~1\dBShell.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\PROGRA~1\ILLUST~1\DBPOWE~1\dMCShell.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashShell.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\WINDOWS\system32\browseui.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\PROGRA~1\SONYER~1\Mobile\FILEMA~1\fmgrgui.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\WINDOWS\system32\Audiodev.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\PROGRA~1\ICQLite\ICQLIT~1.DLL
Sat Feb 17 18:09:51 2007 => Scanning File C:\PROGRA~1\7-Zip\7-zip.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\WINDOWS\system32\mscoree.dll
Sat Feb 17 18:09:51 2007 => Scanning File C:\WINDOWS\system32\ieframe.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\ieframe.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\upnpui.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\PROGRA~1\MICROS~2\OFFICE11\msohev.dll
Sat Feb 17 18:09:52 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
Sat Feb 17 18:09:52 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\Explorer.exe
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\userinit.exe
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\gptext.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\fdeploy.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\dskquota.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\iedkcs32.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\scecli.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\System32\cscui.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\appmgmts.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\crypt32.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\cryptnet.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\cscdll.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\wlnotify.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\sclgntfy.dll
Sat Feb 17 18:09:52 2007 => Scanning File C:\WINDOWS\system32\WlNotify.dll
Sat Feb 17 18:09:52 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Sat Feb 17 18:09:52 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
Sat Feb 17 18:09:52 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
Sat Feb 17 18:09:53 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AEDEBUG
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\drwtsn32.exe
Sat Feb 17 18:09:53 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\ntsd.exe
Sat Feb 17 18:09:53 2007 => Scanning HKCU\Control Panel\Desktop
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\CLAAST~1.SCR
Sat Feb 17 18:09:53 2007 => Scanning HKLM\SYSTEM\CurrentControlSet\Control\WOW
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\ntvdm.exe
Sat Feb 17 18:09:53 2007 => Scanning HKLM\SOFTWARE\Microsoft\Active Setup\Installed Components
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\ieudinit.exe
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\inf\unregmp2.exe
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\ie4uinit.exe
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\RunDLL32.exe
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\shmgrate.exe
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\regsvr32.exe
Sat Feb 17 18:09:53 2007 => Scanning File C:\PROGRA~1\OUTLOO~1\setup50.exe
Sat Feb 17 18:09:53 2007 => Scanning File C:\WINDOWS\system32\rundll32.exe
Sat Feb 17 18:09:54 2007 => Scanning File C:\WINDOWS\system32\ie4uinit.exe
Sat Feb 17 18:09:54 2007 => Scanning File C:\WINDOWS\system32\Rundll32.exe
Sat Feb 17 18:09:54 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run
Sat Feb 17 18:09:54 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run
Sat Feb 17 18:09:54 2007 => Scanning HKLM\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Run
Sat Feb 17 18:09:54 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Run
Sat Feb 17 18:09:54 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Sat Feb 17 18:09:54 2007 => Scanning File C:\WINDOWS\SiSUSBrg.exe
Sat Feb 17 18:09:54 2007 => Scanning File C:\WINDOWS\Mixer.exe
Sat Feb 17 18:09:54 2007 => Scanning File C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
Sat Feb 17 18:09:54 2007 => Scanning File C:\WINDOWS\system32\RUNDLL32.EXE
Sat Feb 17 18:09:54 2007 => Scanning File C:\WINDOWS\system32\NeroCheck.exe
Sat Feb 17 18:09:54 2007 => Scanning File C:\PROGRA~1\SPYWAR~1\SPYWAR~2.EXE
Sat Feb 17 18:09:54 2007 => Scanning File C:\PROGRA~1\ICQLite\ICQLite.exe
Sat Feb 17 18:09:54 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
Sat Feb 17 18:09:54 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx
Sat Feb 17 18:09:54 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices
Sat Feb 17 18:09:54 2007 => Scanning HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServicesOnce
Sat Feb 17 18:09:54 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Sat Feb 17 18:09:55 2007 => Scanning File C:\PROGRA~1\Ahead\NEROBA~1\nbj.exe
Sat Feb 17 18:09:55 2007 => Scanning File C:\WINDOWS\system32\ctfmon.exe
Sat Feb 17 18:09:55 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
Sat Feb 17 18:09:55 2007 => Scanning File C:\PROGRA~1\ICQLite\ICQLite.exe
Sat Feb 17 18:09:55 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx
Sat Feb 17 18:09:55 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices
Sat Feb 17 18:09:55 2007 => Scanning HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce\Setup
Sat Feb 17 18:09:55 2007 => Scanning HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Sat Feb 17 18:09:55 2007 => Scanning File C:\WINDOWS\system32\CTFMON.EXE
Sat Feb 17 18:09:55 2007 => Scanning HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
Sat Feb 17 18:09:55 2007 => Scanning HKCR\txtfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\comfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\exefile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\dllfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\batfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\piffile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\scrfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\scrfile\shell\config\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\regfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\htmlfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning File C:\PROGRA~1\INTERN~1\IEXPLORE.EXE
Sat Feb 17 18:09:56 2007 => Scanning HKCR\htafile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning File C:\WINDOWS\system32\mshta.exe
Sat Feb 17 18:09:56 2007 => Scanning HKCR\jsfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning File C:\WINDOWS\System32\WScript.exe
Sat Feb 17 18:09:56 2007 => Scanning HKCR\jsefile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\vbsfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\vbefile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\wshfile\shell\open\command
Sat Feb 17 18:09:56 2007 => Scanning HKCR\wsffile\shell\open\command
Sat Feb 17 18:09:56 2007 => ***** Scanning StartUp Folders *****
Sat Feb 17 18:09:56 2007 => ***** Scanning C:\Documents and Settings\User\Nabídka Start\Programy\Po spuštění Folder *****
Sat Feb 17 18:09:57 2007 => Scanning Folder: C:\Documents and Settings\User\Nabídka Start\Programy\Po spuštění\*.*
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Nabídka Start\Programy\Po spuštění\desktop.ini
Sat Feb 17 18:09:57 2007 => ***** Scanning C:\Documents and Settings\User\Plocha Folder *****
Sat Feb 17 18:09:57 2007 => Scanning Folder: C:\Documents and Settings\User\Plocha\*.*
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Total Commander.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Zástupce - bigpat.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Zástupce - Karty.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Zástupce - prsi.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Zástupce - BubbleBall.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Zástupce - Jednotka CD-ROMhorní.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\DVD Shrink 3.2.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\MV2Player.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Zástupce (2) - Jednotka CD-ROM dolní.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\WinRAR.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\dBpowerAMP Music Converter.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Winamp.lnk
Sat Feb 17 18:09:57 2007 => Scanning Folder: C:\Documents and Settings\User\Plocha\Nepoužívané odkazy plochy\*.*
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Nepoužívané odkazy plochy\Easy-PhotoPrint.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Nepoužívané odkazy plochy\OptimAccess Dial.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Nepoužívané odkazy plochy\Adobe Reader 6.0 CE.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Nepoužívané odkazy plochy\dMC Audio CD Input.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\Nepoužívané odkazy plochy\PC Inspector File Recovery.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\MiraScan 6.1 (5150C).lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\SiMoCo.lnk
Sat Feb 17 18:09:57 2007 => Scanning File C:\Documents and Settings\User\Plocha\CCleaner.lnk
Sat Feb 17 18:09:58 2007 => Scanning File C:\Documents and Settings\User\Plocha\Opera.lnk
Sat Feb 17 18:09:58 2007 => Scanning File C:\Documents and Settings\User\Plocha\WinAVIVideoConverter.lnk
Sat Feb 17 18:09:58 2007 => Scanning File C:\Documents and Settings\User\Plocha\123 Free Solitaire.lnk
Sat Feb 17 18:09:58 2007 => Scanning File C:\Documents and Settings\User\Plocha\VSO DivxToDVD.lnk
fredik
člen Security týmu
Příspěvekod fredik » 17 úno 2007 19:11
Z logu se nedá nic vyčíst ale máš aktuální verzi a zvolil jsi metodu Scan & Clean tak by měl většinu těch problémů Mwav odstranit sám. Pokud ti i po jeho použití zůstalo těch 16 chyb tak s tím už asi moc nenaděláš.
Podívej se na tento návod tam je napsané co sem vložit: Mwav
Damned
Tvůrce článků
Master Level 9
Master Level 9
Příspěvekod Damned » 18 úno 2007 00:02
Přesně jak píše :bigups: fredík Pkud zapneš Scan&Clean,odstraní ti šmejdy sám,a pak nabídne restart (reboot) a po restartu se ještě jednou spustí. Samozřejmě ale před spuštěním Scan&Clean zapni Update,aby si měl nejnovější databázi šmejdů. Po aktualizaci teprve čisti
