Tip na dnešní den: http://www.giveawayoftheday.com
My Film Kiosk 2.5
My Film Kiosk is a video library management system for YouTube, MP4, DVDs and BluRays. Build up your library quickly and easily by downloading covers and video links from YouTube and our high quality cover database or by manually entering the information yourself. Then catalogue, group, filter and watch.
Giveaway of the Day - Tip na dnešní den! Vyřešeno
Re: Giveaway of the Day - Tip na dnešní den!
SSD Fresh 2015 Plus
Increase the lifetime of your SSD drive with SSD fresh 2015. Adjust the system to the SSD, avoid write access, increase performance. SSD Fresh fits your Windows system to the use of an SSD, reduces the number of read and write operations, disables unnecessary services and thus increases the lifetime of your drive.
SSD Fresh 2015 Plus
Leawo Blu-ray to MKV Converter 2.1
Leawo Blu-ray to MKV Converter offers exclusive and practical solutions for Blu-ray/DVD to MKV conversions in simple operations. With advanced disc decrypting tech support, Leawo Blu-ray to MKV converter can easily decrypt Blu-ray discs with AACS, BD+ and the latest MKB level protection, and CSS-DVD discs to convert Blu-ray/DVD movies to MKV formats with lossless quality. For better movie experience, this Blu-ray/DVD to MKV converter allows to retain multiple subtitles and audio tracks from source Blu-ray/DVD contents, preview subtitles and audio tracks, and play back source Blu-ray/DVD movies with ease.
- Přílohy
- 11050746_1029842220364170_8651016572104660518_n.jpg (20.09 KiB) Zobrazeno 4941 x
EZTalks Premium 10
EZTalks is a powerful web conferencing solution that lets you share your screen and files with people around the world. With it, you can view as many simultaneous streams as you can. Besides, you can virtually conduct your video conference with up to 1,000 people.
EZTalks Premium 10
- Přílohy
- eztalks-120.jpg (2.83 KiB) Zobrazeno 4888 x
Hard Drive Inspector Pro 4.30
Imagine how you would feel if you had suddenly lost all the data from your computer: all documents, e-mails, addresses, accounts, saved passwords, photos, music, and video. Sounds like a nightmare, doesn’t it? But that’s exactly what will happen when your hard drive, a computer part which stores information, crashes. Since the hard drive has constantly rotating mechanical parts it suffers from wear and tear it can break down any moment without prior notice leaving you with ashes, naked. Yes, a hard drive is just a piece of metal and easy to replace, but can you as easily restore its unique contents reflecting years of your life and work?
Ath Tek DigiBand 1.8
AthTek DigiBand is a piece of automatic music composition software for Windows. It can automatically compose music with flexible instruments and melodies. It can also improvise an accompaniment to imported audio files, live computer keyboard playing or humming.
Wise Folder Hider Pro 3.23
Wise Folder Hider Pro can hide files and folders on local partitions or removable devices. The files will be hidden safely due to it adopts advanced encryption algorithm. You can set a password for it so that the hidden data can be displayed and unhidden only by entering the valid password. The data is completely invisible to other programs or on other operating system, so it is much more reliable
Dnes hra v hodnotě 9,99 $$: Eternal Journey: New Atlantis
Tenorshare Video Converter 5.0
Tenorshare Video Converter combines video conversion and editing into one well-built application. It allows you to convert video and audio to an optimum format for your computer and mobile devices in an extremely fast speed with no quality loss. You will also get a list of video editing features like Crop, Trim, Add watermark and Add subtitle. With this video converter, you can easily convert video to AVI, MP4, WMV, MKV, 3GP, DVD movies, MP3, HD videos (AVCHD, M2TS, MTS, MOD, etc.), iMovie, iPad, iPhone, PSP, Android phones, Apple TV and more.
TweakBit PCSpeedUp 1.6.8
PCSpeedUp runs a comprehensive checkup on your system and detects every issue that may be slowing it down. We have developed powerful scanners that zero in on registry errors, fragmentation, incorrect system or Internet settings and other speed thieves for a precise verdict.
COVERT Pro 3.0.9
COVERT Pro – an innovative solution to ensure total privacy while working at the computer. It protects against spyware. When working in secure platform, all user’s actions in all applications (browsers, email clients, office software, messengers, etc.) are safely hidden. Capturing data from keyboard input and monitor screen is blocked. Using special features of COVERT Pro (Network monitor, Driver monitor, System processes, System services) allows you to detect and remove all hidden applications.
To protect against spyware, COVERT Pro uses the masking method. It is the most reliable method against spyware — masking action of user. It means creation of secure platform, inside which user can run any applications, while remaining invisible to the spies.
Search for spyware on the hard drive is ineffective if it’s not in the malware databases. Analyze the code or behavior is also pointless — it is not known who and for what purpose carries specific to spyware actions. Intercept keyboard input and screen captures can perform legitimate software and it is not prohibited actions.
COVERT Pro has user interface in five languages: English, German, Italian, Czech and Russian.
COVERT Pro is compatible with other antivirus programs and enhances the protection of your PC.
COVERT Pro 3.0.9
Smarty Uninstaller Standard 4.1.2
Smarty Uninstaller is a software that allows you to completely uninstall programs (64 and 32-bit) installed on your system. It monitors the built-in application uninstaller and uses an advanced scan engine that deletes any program leftovers. It allows you to launch the scan engine manually at any time to force uninstall a program with broken uninstaller. Featuring an intuitive and modern interface, Smarty Uninstaller displays in the main window all installed software, broken installations, system components and Windows updates.
- Přílohy
- SmartyUninst.jpg (5.29 KiB) Zobrazeno 4529 x
PrintableCal Basic 1.6
PrintableCal is a Microsoft Word and Excel add-in for generating printable calendars containing data from a variety of sources, including VueMinder, Google Calendar, iCloud, Outlook, holidays, iCalendar files or URLs, and more. PrintableCal comes loaded with a variety of calendar templates and settings.
- Přílohy
- PrintableCal.jpg (4.78 KiB) Zobrazeno 4408 x
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 36 hostů
